evan86clc200
Hi all,
Thanks alot in advance of any responses.
My car is in a limp mode, it drives but does not change up. It showed 3 fault codes on my reader, I cleaned the MAF in the holder, noticed the bottom clip of the air intake manifold was undone, and cleared faults.
Only one appears now. The car was jolting into Drive and Reverse and since cleaning the MAF, this has stopped. BUT, it STILL won't change gears. The Transmission fluid is full, was working just fine, so I am confident(ish) it is something electrical. I drove down a long dirty dusty road with bumps just before the problem occurred, so it makes sense that the MAF got dirty.
The P205A code is a Reductant Tank Temperature Sensor Circuit - according to google, says it could be faulty.
Would disconnecting the negative help clear this code? When I clear it with my OBDII reader, it just comes back on straight away.
The battery was sitting at 12.1-12.2 volts and is 10 years old, I charged it and now its 12.5v.
Any advice on why it is not changing, where this sensor is located would be greatly appreciated.
I m on holiday with the car in Europes most expensive country, Norway, so i really need to work this out myself.
BR
BR
