MBC DIY Health days Days Part 1
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
Right im begining to think that we don't pay enough attention on our cars so from Sunday - Saturday we will have a DIY health check.
This week : Tyre pressures !
I want you to post what car you have, size and type of alloys.
The reading should be like this:
Car: Mercedes Dream Class
MB reccomended Tyre pressure FRONT: xx PSI/BAR
MB reccomended Tyre pressure REAR: xx PSI/BAR
Before tyre pressure FRONT Drivers: xx PSI/BAR
Before tyre pressure FRONT Passangers: xx PSI/BAR
Before tyre pressure REAR Drivers: xx PSI/BAR
Before tyre pressure REAR Passangers: xxPSI/BAR
After tyre pressure FRONT Drivers: xx PSI/BAR
After tyre pressure FRONT Passangers: xx PSI/BAR
After tyre pressure REAR Drivers: xx PSI/BAR
After tyre pressure REAR Passangers: xxPSI/BAR
no Excuses! If you need to find out what your tyre pressure is please post another thread in wheels and tyres or look inside your fuel filler cap.
pammy
North Yorkshire
hers - slk 320, his - dull diesel BMW fleet :/, Xtrail, Honda CBR 1100xx, Yamaha YZF600, Ribble Road
Yikes - yes boss!! :D Does this mean I'm gonna have to battle with that mind of its own air hose at Morrisons :crazy:
OK - done
Car: Mercedes SLK 320
16" Mercedes Alloys, Michelin Pilot Premacys all round
front tyre 205/55 R16 91W
Rear tyre 225/50 R16 92 W
MB reccomended Tyre pressure FRONT: 30 PSI
MB reccomended Tyre pressure REAR: 33 PSI
FRONT Drivers: Before 26 PSI After 30 PSI
FRONT Passengers: Before 24 PSI After 30 PSI
REAR Drivers: Before 28 PSI After 33 PSI
REAR Passengers: Before 30 PSI After 33 PSI
Thanks for the nudge ;)
GRAV888
Rochester and Lancashire
2017 CLA 180 AMG in Black (mine) 2018 GLA 200 SE in Black (wifes)
Car: Mercedes C180 Esprit
Recommended Front: 2.1 Bar / 30 psi
Recommended Rear: 2.3 Bar / 33 psi
Actual N/S/F 30 psi
Actual O/S/F 30 psi
Actual N/S/R 32 psi
Actual O/S/R 33 psi
Mercedes 15" 8 hole alloys with wider tyres.
205/60/15 Front
225/60/15 Rear.
@ Koolvin,
did I pass the test? :confused:
Edited to add: Got a puncture in n/s/r that will be fixed tomorrow.
RichardM
Essex
2011 CLS350 CDI
Car is going in for a service tuesday, think I'll let them do it (and then check it next weekend!)
gklau
Leicester
C180K Avantagarde SE
Car: Mercedes C180K
17" Mercedes Alloys, Michelin Pilot Sports
Fronts tyre 225/45
Rears 245/40
MB recommended Tyre pressure FRONT: 30 PSI
MB recommended Tyre pressure REAR: 33 PSI
Actual: FDS - 30 PSI, RDS - 33 PSI, FPS - 30 PSI, RPS - 33 PSI :rock:
Just checked them last week ;)
OP
OP
Koolvin
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
Mine were out as well! I already did mine this morning but forgot to write down the readings - it's what prompted me to do this DIY
fuzzer
Glasgow
F25 X3 20d SE
that all sounds like too much work.....
I hope you all used cotton gloves from your toolkits to touch the tyres :)
Shude
Hardcore MB Enthusiast
Cheshire
CLK55 AMG
My tyre pressures are checked daily, as I have a leaking valve on one tyre, it needs re-inflating almost from zero pressure every couple of days. Sadly I can't really afford to repair it right now :(
guydewdney
Porlock, Zomerzet
906 Sprinter 313cdi
fr, 29 should be 30
fl 30
bl 35 should be 32 (left over from long fast trip loaded in france)
br 35 - as above
255/45/ZR 18 pirreli Pzero asymmetics
sym
North London
W204 C220CDI Sport
So what techniques / equipment do people use to check this stuff at home ? Having had to put my pressures up and down a few times over the last few weeks (as moving house and using car as a removal van!!), each different forecourt inflator that I have used has shown different readings !
I was looking at a cheap 12V inflator, but the gauge didn't seem very accurate (went from 0 - 120 psi !!) . . . so would one of those, and a decent pressure gauge do the job ?
S.
Simon
East Northants
C180 Proper gearbox
Just been out and given them all a kick, seems OK :)
I'll do it properly later.
Ian B Walker
Freckleton
300-24, saloon and coupe, E300 24 valve diesel estate
Mercedes 260E
16 inch 8 hole alloys
(before) front 32 left 34 right
(after) 34 left 34 right
(before) rear 36 left 36 right (left them alone)
Oil..........1/4 pint
topped up washer fluid
antifreeze level ok
Stearing pump level spot on
auto transmission level spot on
petrol.............need to visit local garage asap lol
guydewdney
Porlock, Zomerzet
906 Sprinter 313cdi
iirc one of the car / bike mags did a test not that long ago - the halfords own brand pencil type came up as almost perfectly accurate against a "snap-on" digital one...
hth
Guy
portzy
Ulrome, Driffield, East Yorkshire.
An SLK R171 with lots of toys and a Golf Plus for fishing.
MBC diy health days
C200K SportCoupe.
17" Seven spoke Evolution alloys
Michelin Pilot Sport 225/45 front and rear.
Per the petrol flap:-
N/S/F 36 psi
O/S/F 36 psi
N/S/R 39 psi
N/S/R 39 psi
These are the maximum i.e. 4 up plus luggage, this is what I prefer as I find she (she! :eek: ) handles better, honest, really!
Actual this morning was as above ;)
This afternoon about 1 psi higher due to ambient temperature and having recentley arrived home and parked up.
Forgot to mention, I have one of those digital gauges which I bought from Woolies in a sale I calibrated it at work and it is spot on :D
GrahamC230K
Audi A3 & S4 quattro
Maybe we need to revive this!
I am normally very good with keeping track of checking pressures etc, but today it was only until I noticed the car was handling very odd (tail happy exiting a dry roundabout at non excessive speed) that I visually checked the tyres.
Drivers rear looked a bit low - it was 14psi. Oops!
Just need to find out if it's going to stay up now or not. Seems a lot of pressure to loose considering others were all spot on, but it went up ok and no obvious nails etc.
marcos
Hertfordshire
C43 estate
I've been having handling probs for a while now and someone told me why last week.
The white nylon stuff was showing through on the fronts :eek: :eek: :eek: :eek: :eek: :eek: :eek:
I can't believe that a 34yr old was driving around with bald/falling apart front tyres in a 40k car. I need help.
BTW it's all sorted now and handles like a dream again. :D
GrahamC230K
Still up today, same pressure.
How did one tyre loose 16psi without having a puncture?
Brian WH
East Midlands
JAGUAR XF 3.0D Premium Luxury
Possibly a leaking valve, which has now cleared since you blew air through it mate. Keep an eye on it and check valves with spittle test. ;)
