Media split screen?
podge2207
Wigan
2016 Mercedes 220d sport
Can anyone tell me if it's possible to show Radio and SatNav together on the media screen in my 2016 220d sport? I have seen something on YouTube but it appeared to be different to mine. Can't see anything in the vehicle instruction book.
Welcome.
Your 2016 W205 C220d will have either Audio20 with the optional Garmin Map Pilot navigation on SD-Card, or COMAND NTG5*2 with built-in navigation.
Do you know which one you have?
Welcome.
Hi, As I know it has an SD Card, I presume it's the former.
Thanks for the welcome.
COMAND has an SD-Card slot as well... it's just that on COMAND the SD-Card slot is not used for navigation, instead the navigation software and maps reside on an internal HDD.
On Audio20, the Garmin Map Pilot navigation and maps reside on an SD-Card, that needs to be inserted in the SD-Card slot for the navigation to work.
When the system is switched-on, does it say 'Do not let COMAND distract you....' or does it say 'Do not let the System distract you....' ?
Mine says the latter "Do not let the system distract you etc....." I bet my system won't let me do a split screen!!
