Alex225
- Aug 23, 2015
- CLS63 AMG
Thought I'd pop up a quick review of this stuff. This isn't the liquid wax but the spray on wet version.
So the car was hand polished and has a sealant applied already. Now the first coat of this stuff goes on when the car is wet but you simply dry the car off whilst it's on the car. This applies a base layer.
On the next application you wash and rinse the car as normal, then spray over the car whilst it's wet.
I've used it with a hose but it reacts more obviously using a pressure washer.
You'll see that the water beads immediately and then you just dry the car.
I've used a couple of similar products, I like Gyeon Wetcoat and I tried Bouncers Bead Juice which both apply with a spray on rinse off method, no base layer as such. I'm quite taken with this stuff though, worth a go and definitely one that's an easy top up to the protection.
