I have a 1992 W126 500 SEL that has covered over 222K miles. In the last 6 weeks or so, the engine has been badly misfiring to the point of cutting out. It is fairly random, but usually occurs after the car has been driven for a while - anywhere between 5 and 120 miles. If it cuts out completely, it restarts immediately. Sometimes, I can drive all the way from London to Manchester without it missing a beat; other times I have driven 150+ miles with it misfiring the whole way.
I had noticed one of the 2 fuel pumps getting a little noisy over the last year or so, but with no other symptoms. When it's misfiring, however, it seems to be accompanied by what I can only describe as a squeaky buzz from the rearmost fuel pump.
The symptoms are a bit like fuel pump relay failure, but I changed this to no effect. I also had the fuel filter replaced. My garage (Merc experts) have looked at everything from fuel pressure to ignition, and can find nothing wrong. They didn't seem to be particularly bothered by the noisy pump, and suggested the crank sensor might be at fault. They don't think it's the pumps, as the intermittent nature suggests an electrical problem. I'm not so sure, but I don't want to commit to the expense of replacing 2 pumps and associated corroded piping if it is a simple electrical glitch.
I'm at my wits' end on this one!
