colin 320cls
- Oct 26, 2015
- merc 320cls
:bannana:Hi All have problem with 320cls.2006 model....sometimes it wont change gear and I have to use the manual change on gear lever several times before it will change up...also if I give a rapid throttle to change down it does not change down. sometimes when in 5/6th gear it will not change down automatically and increasing throttle has no effect...if I use the manual change down it revs up to 3000rpm but car does not accelerate..it seems there is a problem with the communication between engine and gearbox.
Any help most appreciated!!
