7.6 eh?Big Ed said:1999 Mercedes-Benz C230 Komp. 7.6
The "book" reckons something like 8.5 seconds 0-60 for the c230k so if the above figure is anything like accurate then you can safely knock half a second off the "book" 0-60 time for whatever you're looking at for a "true" figureBig Ed said:I've still got the old brochures, so could look up the specifics for you...
janner said:1991 Mercedes-Benz 300CE 24V 8.5 16.6
1993 Mercedes-Benz 300CE Conv. 8.1 16.1
How can the convertible be quicker than the coupe?
Given the ages, the earlier one probably has no catalytic converter, the later one does.janner said:1991 Mercedes-Benz 300CE 24V 8.5 16.6
So it should be even quickerGiven the ages, the earlier one probably has no catalytic converter, the later one does
I just took a look at the figures and of course you're right, the pre-cat ones are definitely faster/more powerful. The 0-60s makes no sense at all unless it's got something to do with the transmission.janner said:So it should be even quicker
edit..
a non-cat 300ce24 has 230bhp and weighs under 1400kg
a 300 conv (3.2) has only 217bhp and weighs over 1700kg
no way is the conv quicker to 60.
