Merc W124 300D (1992) ELECTRIC WINDOW
JWC1982
Berkshire
W124 Mercedes 300d - 1992
Hi, hopefully someone could help?
My Merc which I only purchased yesterday makes a strange noise when I operate the driver's electric window. The window does go up and down fully, but I have to guide it for the last few inches as it makes the terrible noise and appears to go wonky also. Is this the regulator that I've read about or is it the guides or something?
On a slightly related note, the passenger side window doesn't move at all is it on a separate fuse or not or could this be a duff switch?
thanks in Anticipation
JWC
Welcome JWC. Nice car.
Sounds like both your window mechs are duff. Once you have them sorted your car will pay you back in barrow loads.
This is the sort of thing you need to fix your fault.
Mercedes W124 E Class Front Right Window Regulator | eBay UK
The above is for manual window operation but I hope you get my drift.
JWC
Sounds like the last few teeth have worn excessively on the regulator, causing the cog to slip on them. This a common problem with a w124, you can either replace it with another regulator, or do as I have and repair the old one.
To repair the old one remove the regulator from the car, then using a welder fill in the last 4 teeth with weld, and cut some new teeth in this to the correct profile. It takes 10 min's and has never been a problem since (4 years).
The passenger side sounds like the fuse has gone, as in Balge's post above.
Hope this helpful.
