Deen121
Hi I have a mercedes 190e 2.6 and I want to do engine swap from Mercedes w210 3.2 any good garage who can do this kind of job around west Midlands
Straight six to V6? Is there enough width in a w201's engine bay to fit a V6 in?Hi I have a mercedes 190e 2.6 and I want to do engine swap from Mercedes w210 3.2 any good garage who can do this kind of job around west Midlands
Yes ,engine will drop straight in as 2.6 have detachable front slam panel .its the wiring problem.Straight six to V6? Is there enough width in a w201's engine bay to fit a V6 in?
Sorry i have no clue about a w210's canbus apart from knowing it is complex.Yes ,engine will drop straight in as 2.6 have detachable front slam panel .its the wiring problem.
I have a low mileage W210 with only 51k mileage and I wanted to take out engine and gearbox from this vehicle to swap in to Mercedes 190e 2.6 and then fit turbo later on. Can you do the job.The 3.2 V6 is a big job. The 3.2 straight six m104 from a early w210 / w124 is much easier. Been there done that , fantastic
If you are going to go the V6 route may as well go V8 as not much more work !
The 3 litre m103 is more or less a straight swap
