Hi all, I had a problem with my car for a few weeks now, I wonder if I can get some help.
About a month ago the car started refusing to start, turn over ok, just not firing, when it did, it ran perfectly. Took it to a garage, Bosch fuel injection specialists.
They used diagnostics and checked all sensors were good. They checked the afm plate and lowered it a bit, checked the fuel return hose and it was only dribbling back so they suspected fuel pump or filter but they then checked the pressure and found it to be very high, 6 or 7 bar.
So we replaced regulator with a second hand part, pressure was lowered and it was starting ok.
Took the car on holiday for a week, it drove fine daily, the day we came home, after filling up petrol and unloading we went off to supermarket, it wouldn't start.
Paid for a question on website, got a bosch specialist. They suggested the fuel pump and filter or accumulator. They also did not think the pressures I posted looked right and were in fact differential pressure between upper and lower fuel distributor chambers. We bought an acumulator just in case, before we handed the car back to the garage.
The garage checked the pressure again, found it high, so we replaced the regulator again. Pressure came good, car cold started and hot started. They thought the car was ok but when we went to pick it up, it wouldn't start. They had figured out by jumpering fuel pump relay pins 7&8 and giving the pump a few minutes, then replacing relay, the car would start normally. The fuel pump was making a bit of a racket. We had noticed when we got back from holiday the fuel pump was whirring away very loudly, higher and lower when parking the car. He suggested we replace the fuel pump and run the tank low so he could check the fuel filter in the tank.
I had the car at sustained motorway speeds to run it out of fuel but I had nearly a full tank so I decided to buy a syphon hose and use my emergency fuel can repeatedly to discharge the tank into my other car.
We sourced a new fuel pump, spoke to mercedes who informed us there was two pumps, they suggested fuel pump relay, but mine looks new, I removed it and opened it for inspection and it looked clean and relatively new (very shiny) no obvious sign of damage. The car worked reliably by jumpering FPR and replacing relay and starting car.
Garage took the car, when they removed the cover to change the pump on rear drivers side (the noisy one) one of the electrical wires fell off. They saw imeadiately it was a bad connection, remade it, connected it and fired up and all seemed normal. Pumps were silent. They stopped at that point and called us, they didn't want to go any further.
We picked it up, filled up with petrol and in the morning, car wouldn't start. Eventually it got going, we decided to set off on our journey but before we got to motorway, we could hear the pumps whirring away and we decided to turn back.
This morning, I checked the fuel rate by taking feed off fuel distributor and jumpering relay. The jet of fuel was consistent. Filled a quarter of a 2 pint plastic milk bottle in about 10 seconds.
The car started first time perfectly today 3 or 4 times, I used it normally. Figure if I use it until something breaks then I may find out whats wrong.
The end answer from the internet question guy said he had replaced many a tank, fuel pump and filter for rust, but he would not suspect failing fuel pump for too high pressure.
The fuel test today suggests there is no blockage.
I've ordered an FPR from online auction site today.
I've read an exellent thread on this board that has similarities to mine.
Bought the car last December, previously had a head gasket replacement, drove until last month with no issues, pumps were quiet. It did have the remmanants of an alarm system installed when I bought it and I had to undo some wiring in the passenger footwell to get central locking working -wire spliced into central locking, stereo amp installed under footrest, rewired electric closure in boot.
I'm down 2 regulators an acumulator a fuel pump and a few hours labour, its been over a month and we've barely had use of the car.
Any idea's or suggestions?
300TE Fuel Pump Problem
Link - http://www.mbclub.co.uk/forums/engine/38414-w124-300te-fuel-pump-problem.html
