NicoMercedes
I'm wondering if someone could offer some advice on a 2007 Mercedes-Benz C-Class 180 Compressor automatic (W204).
Two weeks ago, I experienced a sudden loss of brake pressure when the engine was idling or the car was rolling. However, when I started driving, the brake pressure returned to normal and worked fine.
After coming to a complete stop, if I let the car roll a bit, the brake pedal becomes stiff at the top with very little or no pressure. Once I start driving again, everything works fine until the next stop. If I turn on the engine and let the car roll, there is still no pressure with a stiff pedal.
I've had the car serviced, and no vacuum leaks were found, and the brake fluid is full. The mechanic suspects that the issue may be with the failing master cylinder or the pump located behind the engine, but they are not entirely sure.
Any input welcome
Any input welcome
