Mercedes-Benz E-Class premiere - The new eight-cylinder diesel engine
Guy
Manchester
Maserati Quattroporte : Brabus A200CDi D3 : E300TDT
The new Mercedes-Benz E 420 CDI: the world’s highest-torque passenger car diesel engine
Stuttgart, May 18, 2005
In autumn 2005, a new Mercedes-Benz E-Class model variant powered by the world’s highest-torque passenger car diesel engine will go into series production. The 231-kW/314-hp V8 powerplant develops maximum torque of 730 Newton metres at engine speeds as low as 2200 rpm. This allows the new E 420 CDI to accelerate from 0 to 100 km/h in just 6.1 seconds on its way to a top speed of 250 km/h. Combined fuel consumption stands at 9.3 litres per 100 kilometres. Among the standard features of Mercedes-Benz’ new flagship diesel model are a maintenance-free particulate filter, seven-speed automatic transmission and AIRMATIC air suspension.
5dt54k
The new eight-cylinder engine powers the E 420 CDI to the top of this market segment in terms of dynamics and smooth running characteristics - and offers exceptional diesel-powered driving pleasure. The imposing pulling power of the CDI engine sees to that, generating in excess of 700 Newton metres as low down 1950 rpm. The V8 reaches its maximum torque of 730 Newton metres at 2200 rpm, guaranteeing not only exemplary flexibility when overtaking and lightning-fast mid-range sprints, but also relaxed cruising in higher gears. The E 420 CDI requires a mere 5.4 seconds to power from 60 to 120 km/h in third gear.
5dt56t
Heading the list of technical innovations in the new Mercedes eight-cylinder powerplant – which also boasts an aluminium crankcase, cooled exhaust gas recirculation and electrically driven intake air throttling – is third-generation common-rail direct injection. This technology raises injection pressure to 1600 bar and allows particularly precise fuel metering, thus reducing both fuel consumption and exhaust emissions. As with all common-rail engines, the driver can count on high injection pressure at all times – even at low engine speeds.
An outstanding feature of the latest CDI technology are piezo injectors in place of solenoid valves. With a response time of just 0.1 milliseconds, piezo ceramic allows fuel injection to be adapted more quickly and precisely to suit changing loads and engine speeds than has previously been the case. This helps to cut emissions, fuel consumption and noise levels. To this end, Mercedes engineers have developed a dual pilot injection system which acts in just a few milliseconds and significantly reduces the combustion noise generated by the eight-cylinder engine. Added to which, double fuel post-injection helps to clean the residue away from the standard-fitted diesel particulate filter.
Improved charge air supply and cooling boosts power output
One particular focus for the Mercedes engineers was the air ducting either side of the turbochargers. Using airflow calculations and simulations, they were able to reduce the loss of pressure typically experienced in the charge air manifolds of turbochargers, leading to a sustained improvement in the supply of air to the engine. The pressure loss in the charge air manifolds has been cut by as much as 60 per cent compared to Mercedes-Benz’ previous eight-cylinder CDI engine. This means that an up to 15 per cent greater air mass can flow into the engine, and the V8 uses this to maximise power and torque development.
5dt5b9
Improved charge air cooling allows further improvements along the same lines. The water-cooled intercooler in the new eight-cylinder CDI engine is integrated into a special low-temperature circuit with two water coolers. Here, the charge air is cooled by up to 120 degrees Celsius, pushing up air density under full load by as much as 25 per cent.
Modifications have also been made to the turbochargers with variably adjustable guide vanes. New vane geometry for the compressor and turbine wheels and the guide vanes makes the new engine more efficient than the previous eight-cylinder CDI unit. Another special development from the Stuttgart-based diesel experts are the hollow inserts in the intake lines, which increase the volume of the air before it enters the turbochargers. This raises torque output at lower engine speeds by some 15 per cent.
5dt5cn
Standard-fitted particulate filter brings exhaust emissions below EU-4 limits
The new Mercedes-Benz eight-cylinder diesel engine is fitted as standard with two oxidizing catalytic converters and a maintenance-free particulate filter system, allowing it to keep below the stringent EU-4 exhaust-gas limits. The catalytic converters have the task of breaking down unburned hydrocarbons and carbon monoxide though a chemical reaction with oxygen (oxidation). The particulate filter does not require the use of additives and is cleaned as required whilst on the move through engine functions such as double fuel post-injection.
5dt5e1
The new V8 compression ignition engine features a sensor in the oil sump which checks the level, temperature and quality of the oil. A display in the cockpit alerts the driver when the next oil change is due. Depending on how the car is driven, maintenance intervals of up to 40,000 kilometres are well within the range of the E 420 CDI.
The new eight-cylinder CDI engine will celebrate its series production premiere in the E-Class in autumn 2005 and will also be made available for other Mercedes-Benz passenger car model series in the future.
Photos & Text courtesy DaimlerChrysler
Nice !!!
Now I wonder if this will go into the CLS...
saorbust said:
Nice !!!
I thought the CLS was based on the 'E', so what goes into one, will go into the other.
Will it grace our shores is a more 'nitty gritty' question. ;)
Regards,
John
Don't you just love it. There we are celebrating Mercedes-Benz new engine, then within the wink of an eye.
Audi breaks diesel power record
Audi has added a new 4.2-litre diesel engine to the A8 range - making its big saloon the world's most powerful diesel car.
The V8 unit, which replaces the outgoing 4.0 TDI, endows the luxury express with a truly extraordinary blend of performance and economy:
322bhp at 3750rpm, 479lbf ft at 1600rpm
0-62mph in 5.9 seconds, top speed limited to 155
30mpg combined, 590-mile range
The engine is mated to a six-speed Tiptronic box as standard, along with Audi's familiar Quattro four-wheel drive. Needless to say, standard equipment levels are impressive.
Still the A8 does not offer an estate car and they make no mention of it going into the A6.
John
John
Figures for the E420 CDi in proper money....
316bhp at 3600rpm, 538lbft at 2200rpm
Autocar reckon MB will sell it in the UK if there is enough interest.
Get your order in Brian!
Yup OK mate. :rock:
I've ordered one for you too. :D
Brian will get it chipped to 5.4 x 10^8989 newton metres of torque, and the earth will wobble every time he drives it somewhere.
:p :p
:D
PJH said:
Oh you are SO kind ! Um, I hope you told them YOU'RE paying.
I knew I'd forgot something - Oops. :eek:
"The water-cooled intercooler in the new eight-cylinder CDI engine is integrated into a special low-temperature circuit with two water coolers. Here, the charge air is cooled by up to 120 degrees Celsius, pushing up air density under full load by as much as 25 per cent."
That sounds interesting. Anybody know if there are any other cars with "wet" intercoolers? Every one I have seen so far is an air cooled heat exchanger.
Good idea, but no doubt a bugger if it goes wrong
SportsCoupeRich said:
there is a 400 cdi available in europe but it will only fit left hand drive cars....hopefully this wont apply to this engine...
I have heard that rumour but am curious as to its authenticity. The S-class is also available in some countries with this engine but again we do not have it.
The 4Matic has not been imported for the same reason, but that makes sense as the transmission tunnel would have its bulge in our drivers footwell.
Regards,
John
