Part
I used ebay for the spring part: It was from X8R Ltd which sell loads of cool solutions to the automotive ‘usual suspects’. 4 springs, they are sided so 2 near side 2 off side – mosquito forceps and a great booklet with loads of offer kits that they sell to fix the automotive industries pants design flaws.
Search for “FOR MERCEDES C E CLK CLASS W203 W211 W209 DOOR LOCK ACTUATOR REPAIR 4 SPRINGS” on ebay and it should come up. I paid £9.99.
Armamentarium
Undo the inner fitting with torx
Pull out SRS cover and undo the screw behind it
Undo door latch surround
Pull off tweeter and tape it up out the way
Pull door card off – towards you then up – it is quite hard to remove – tease it upwards.
Undo the door cable – lift that hook out
Unplug speaker cables, and lower door light assembly – and window controls click out
Tinker with the cable to the actuator to give some slack
Armamentarium
- Hand mirror for looking up at the lock mechanism that you are trying to remove through too small an aperture!
- Torch – one of those hideously bright LEDs is mega useful for looking into the door.
- A selection of screw driver bits is useful
- A set of torx screwdrivers is advisable because opening the bolt which retains the external key mechanism is reached through a tiny hole beneath the rubber door seal – a torx bit in a screw driver will not fit through the hole! E.g. Sealey S0897 8pc TRX-Star* Screwdriver Set. I just got away with it using a naf torx penknife thing which I took apart so it would reach.
- Some masking take to tape the tweeter up out of the way
- A tennis ball (yes you read that right)
- Metal cutting drill bits & a drill to cut out the rivets
- Plastercine or a magnet picker upper – to retrieve your cut rivets.
- Selection of small to medium nuts – to keep safe hold on the external door key assembly and stop the screw falling inwards! I used an MDF style captured nut filling which was a perfect fit.
- Light and magnification and a clean flat surface – for when you are tinkering with the tiny spring and it pings off into the distance!
- A rivet gun and rivets – for putting the black bar back on again.
- A comfy low stool to sit on when working on the door.
