mercedes c180 2011 c204 coupe starting problem
kash123
uk
mercedes c204 c180 coupe 2011
hi guys, new to this thread. not sure if this is the correct place to post this, but if not can you please move it to the correct place.
I have a 2011 mercedes c180 coupe (facelift)- with a 1.8 petrol engine. I'm having trouble starting it. Each time i start it, it tends to start on the third time- after ticking over the first 2 times. this happens almost every time, it will always start on the third time. It does however always start and has never not started on the third attempt. there are no warning light on the dash. I have changed the CPS sensor and the map sensor but still no luck with fixing this problem. I also have go the battery checked and that was fine.
Any advice on this matter would be helpful.
I have searched the forum and haven't found anyone with a similar problem like this- as it does a pattern of starting on the third time.
