I've recently acquired a 2005 Mercedes c220 cdi, shes got a few issue's
Already clean the original EGR valve as had a P0404 AND P0403
Now along with C01022 & C01038 which will not reset both of which are ESP Tracs Error's , i have NO Tracs ABS warning lights on the dash ever,
Limp mode is intermittent
It has a Fault where it goes into limp mode 99% on partial throttle, and stop the car and turn ignition on and off will usually clear it and it doesn't bring on the CEL
One thing i do notice is The Speedo and RPM fluctuate by about 25rpm and 1mph when cruising.
The Car has also had a replacement MAF and MAP sensor, no intake leaks present.
I am wondering whether the conductor plate in the gearbox is giving up the ghost as ive had the bouncing of the Rpm needle before and it was the fault
