Keith b
Hi I have a Mercedes c220cdi w203 which has a leaking exhaust manifold gasket so I bought the gasket plus turbo gasket I also have a Haynes manual for reference,so removed airbox and heatsheild then read manual, it says to gain access remove nut on cat mounting bracket at the rear then access and undo manifold bolts,did what the manual said and hey presto no way whatsoever to access the bottom back bolts on the manifold,looks like you have to remove the cat to get to the back bolts am I right ? that just looks like a nightmare surely that's not the case just to get at two nuts .Oh and just to compound my misery the reason the manifold is leaking front top exhaust stud has snapped any tips tricks would be appreciated,.. thanks k
