- Nov 27, 2004
- Location
- Southampton
- 65 Plate E350 CDI Convertible, 2006 CLS 55 AMG, 1997 C230K, 1999 C43/55 AMG
so what battery did you buy in the end Andy?
Strangely I have my ctek wired into the pos & neg terminals of the battery via the quick release connection - My current battery throws a red light on the charger when it reaches step 5 on the Ctek - manual states my batt is not holding a charge properly
Looks like I may need one too
I ended up buying a Varta AGM Battery (019), since fitting I have not seen the convenience functions disabled message at all, has been left for two weeks not being used.
Incidentally I thought I would start checking for the battery drain, yesterday after a STAR session, I left the boot lid open used a screwdriver to throw the boot latch over so the car thinks the boot is shut, put on my Ammeter on the -VE of the battery and a I now have a drain of only 30-40mA which is within spec (MB say it should be less than 50mA). The only thing I did when connected to STAR was cleared all the fault codes, and re-started the fibre optic ring of the Command system, whether doing this was responsible for the drain I do not know, wish I had done the test before connecting to STAR now.
