Mercedes e class w213 epb fault B23AA11
ghanch
Bolton
Mercedes c class
Hi, please can somehelp , i have the the following fault code B23AA11 fault code - THE LEFT BRAKE CALIPER HAS A MALFUNCTION. THERE IS A SHORT CIRCUIT TO GROUND. im after a dealer wiring diagram for the left rear parking brake motor on a mercedes e class w213 , vin WDD2130042A094612. It keeps showing a short circuit fault. Replaced caliper already
Have you checked the wiring and the electrical connections?
Yes i have checked connections, i have fitted a new caliper but same issue remains. I have checked the small loom under the wheel arch and that is ok. I haven't checked the harness in the car tho. Thats why i wanted a wiring diagram
You need a full Star /Xentry diagnostic.
