Mercedes E320 CDI W210 Indicator stuck on left signal
Mercedes cozy
LONDON (Near Heathrow Airport)
Mercedes ML 320 CDI W164 KEYLESS GO / (NOW WITH STAR)
My work mates car had the indicator signal stuck on left turn.
No matter what you did by moving the stalk up or down, it would not switch off.:devil:
Lucky i had a spare stalk put it in and everything back to normal.:bannana:
So this is the fix if you get the same problem.
i have a same problem with 2001 320 SLK. left signal stuck on unless you turn right signal on. whats the problem??
You don't think the advice from Mercedes cozy was enough? You might try cleaning with compressed air and some appropriate cleaner but the cure would be temporary if any.
I guess you don't accept "avoid turning left". :rolleyes:
