09mercman
hi guys i have just had my injector seal's(all) and one injector replaced as well as all the brake disc and pads and a pully tensioner as well as maf sensor.
all done and working fine but yes there is a but the car is letting off a bit of black smoke on hard throttle? but when MAF disconnected it is very minimal.
ok so the number one injector was letting to much fuel flow so changed for another refurbished one.
after fitted mechanic programmed in and then went to start the car and nothing no even a squeak so put it on a machine and the code came as P1617-064 - EEPROM or incorrectly coded No harmonizing version number -----P1617 eeprom or incorrectley coded AT has been coded as MT.
so called around all day Saturday and all day sunday and found a guy who said he will come and have a look he connected a wire to the starter and it started no problem but when switched off it will not start again. tried to clear the errors no luck at all.
pleas pleas can anyone shed some light on this urgent this car is my only sourse to get around to and from work.
