Mercedes 'one button' key fob battery
babz
Newcastle Upon Tyne
1996 Mercedes C180
hi guys, my battery on my key fob is kind of dying out. if i replaced the battery inside would it mean i have to reprogramme the key? or is it just simply replace it and go? :dk:
thanks in advance!
thanks in advance!
Just swap out the batteries. Nothing else required
replace it staright away and all will be fine once removed if left for a long time depending on key type it may need to be
if its a single button type and you have a mirror with red and green lights on it then
reprogram is easy point key at mirror and press and hold button for 5 seconds then put into slot 2 in barrel and count to 20 sec all done but you should be fine changing straight away
thaks for the info horgantrevor, ill be sure to keep it in mind.
