D
Deleted member 11979
Guest
I have a problem with the factory fit electrics on our 2011 GL.
With the ignition off and for maybe 5 seconds after turning it on, all the trailer lights work correctly. The lights are filament.
Once the ignition is on only the trailer brake lights work, the others giving the blown bulb message on the dash as you try to use them (once you indicate for exampleit throws up the blown bulb message for that bulb and the bulb doesn’t light)
All the fuses seem ok, it’s been on a Star machine and no faults found.
Before I randomly shell out for a new SAM does anyone have any ideas?
Many thanks
Many thanks
