For sale is the rear lights in clear. These are genuine with the reflectors on the indicator housing. Two fronts are genuine but one has a hair line crack and chip in corner. One brand new front which perhaps you can swap with a breaker to complete the other set. Two side repeaters (in yellow) and two rear reverse housing. Easy fit and makes your old w124 classic that little bit more modern! Postage to most areas of UK £8 by DHL. Priced to clear - cheaper than the breakers!
(so basically two lefts and one needs swapping for a right to make up the set)
Picture here: Adings - Mercedes w124 Clear Lights (250d, 300d, E200)
Click on the picture to go large.
Would swap for a 250d differential (manual).
