833steven
mercedes w124 m111 engine automatic surge forward on moving
i have a mercedes w124 convertible m111 engine automatic its 1994 with just under 17000 miles in gear ticking over its at approx 600 RPM at tick over IN park its at 1000 at tick over when hot when you pull away you cannot pull away smoothly it will surge forward you can get round it by applying a little pressure on the brake pedal .Its as if its dropped out of gear on tickover and then when you speed up the engine it suddenly gets enough fluid pressure to start driving the car .A ll filters and fluids have been changed the auto gearbox fluid was very clean and so was the filter i cannot believe it was like this from new any ideas thanks steve
