GT160
Hi all,
Would really appreciate any help in tracing down the parasitic electric drain, Ive spent a lot of time narrowing it down but have not managed to solve/pinpoint the problem. Heres what i know so far using a multimeter, unfortunately I dont have any access to STAR .
I followed the process of locking doors, bonnet, boot so car thinks its locked, left for about 30 mins, removed battery negative, connect multimeter to battery post and to the removed battery negative clamp.
Total Drain is 400MA
Removed Fuse 8,9 from the rear and the myterious fuse 23 (still not quite sure what it does as the fuse diagram does not seem to make it clear and ive driven a week without it in and havent noticed anything??)
Removing all three fuses I have a lovely drain of only 60MA
I put fuse 8 back in drain + 70MA = 130MA
I put fuse 8 and 9 back in drain + 220MA = Total of 350MA
I put fuse 23 back in and drain is a further +50 = Total of 400MA
So then went off to search for the cause of the drain,
1) Fuse 8 belongs to alarm and central locking, so common fault appears to be the alarm so i unplugged the alarm and the drain from fuse 8 goes away , so a faulty alarm is most likely suspect, i tested and i dont think the alarm works anyways as i open the car from inside whilst locked and the hazards flash but no siren, so logic would suggest i change the alarm and the drain should go away?
2) Fuse 9 refers to the interior lighting, so i removed the dome light in the front to take a look. Everything seems to work fine with the dome light, the only thing im not certain off is whether the light actually comes on with the opening and closing off the doors, it seems to suggest it only does this when dark....where is the light sensor for these? Anyhow i thought fault module maybe and found a replacement used unit and thought i would take a punt at £10. Anyhow again everything seems to work, but the drain is still at 400MA
3) Anyone any idea what fuse 23 does.
Any help would be greatly appreciated, its not a problem as such as i have just been using the car with the fuses out but im restoring and returning the car to my dad and would like to make it back to perfect condition but we are both scratching our heads on where the problem is
Thanks in advance
Thanks in advance
