RobertE270CDI
Hi e270cdi wont start When the key is turned to start position the starter clicks for a millisecond and the brake peddle pumps . Checked all fuses and relays . Put Mercedes star SD connect on car and the only item was a fault in the glow plug relay short circuit and 3 and 5 glow plugs gone . Rear battery has been drop checked and it fine but reading only 11.8 volts with ignition on . Auxillary battery is reading 12.80 volts Any ideas ?
