Hi all.
I have a problem with 2007 S500 air conditiong in that it is not very effictive. I had the system vacum tested and filled with the correct amount of gas for the model twice now. No fault codes stored or current which was checked on SDS and passes all the tests. The problem is when warm say 22c when the interior fan is in auto and temp is set low and the fan spped high the evaporator temp reading is much the same as the ambient temp. Set to manual say fan setting 2 and the temperature at the evaportor sensor starts to drop towards 9-10c and the air at the vents start to drop to much the same as expected. Once the fan setting goes above 3 the temperature at the sensors and vents starts to rise again. All the vents / motors are working correctly and have been set up correctly.
So does anyone have any ideas please?
