charliefarlie
- Sep 16, 2011
- Location
- lockerbie scotland
- mercedes C250 diesel estate plus a sprinter 312 camper G wagen xv750trike yamxj750 maxim
Have a wee problem with my merky benz C250 Turbo diesel 1998 on an s reg ,she starts fine no probs up till the frost arrived then was dificult to start would start after preheat light went out as normal but would stop more or less imeadiately would try again same thing on the third go it went fine went all day no probs the following day same again but slightly different started then stopped hasnt started since the out side temp was minus 6 its now thawing and temp has risen out side to 4 over nil so getting less cold still it wont start even with charge booster on battery turn ignition on wait till glow plug light out then turn the key a litle further over turns engine but not fireing up , am wondering if it might be the heater plugs as engine turns over fine just not fireing .
I was wondering if there is an electronic switch or sensor gone phutt as cant see all 5 heater plugs going all at once unless of course their was only a couple working before the cold weather started and yes loads of diesel in the car .
Any thoughts on the matter before i take it to bits , any replies would be much appreciated thanks charliefarlie
