Metal Dust Cap Warning
GrahamC230K
Audi A3 & S4 quattro
I know that my chrome dust valve cap mod was one that you all stood back to admire.................................
OK, so nobody actually knew I had them, but I DID :p
No not theft for a local BMX, when I went to test my tyre pressures this morning, I found all but one to be totally stuck on the valve.
I have had such metal dust caps for a few years now across a few cars and have never had this problem.
Long story short, mole grip and plyers, WD40 these were not comming off without the valve with them.
Trip to local Tyre shop, he finsihed my sentance for me when I said "I have metal dusct caps and they are...."
Apparently quite common.
It only cost me £10 to have 3 new valves fitted to car, which I am happy with.
Crappy black plastic dust caps for me from now on.
Learn from me, I would not have believed it, but be warned.
Mark300SL
1962-2010. Gone, but not forgotten.
My Rover ones have a bit of coppaslip on them !!
They come off easy enough
Mark
GRAV888
Rochester and Lancashire
2017 CLA 180 AMG in Black (mine) 2018 GLA 200 SE in Black (wifes)
I have had metal dust caps on my car for a year now. When I put them on, I put a thin smear of copper grease round the thread of the valve. This lasts a lot longer than normal grease, but do not get it on your clothes as it is very hard to get off.
OP
OP
GrahamC230K
GrahamC230K
Now you tell me!!!
Live and learn.................
Mark300SL
Originally posted by GrahamC230K
Now you tell me!!!
You never asked !! :)
I have posted a lot of my info on here - but I dont have anything like enough time to post all of my info here!!
Tip - put a bit of coppaslip on your wheelnuts and back face of your alloys - then the wheels will undo and come off nice and easily.
I also use it on Manifold bolts, turbo bolts (whoops you dont have one of them :)), and anything else that might possibly sieze !
HTH
Mark
Paul
Sittingbourne, Kent.
2011 E220
I dont have to worry about my metal caps siezing, some b**tard nicked them :mad: .
Since then I just put a bit of silver paint on my black plastic ones :) , or am I just tight :rolleyes: .
Dont answer that one Mark :p .
fuzzer
Glasgow
F25 X3 20d SE
Ive got nice 60p plastic jobs out of halfords after replacing a full set of them about 3 times i got fedup and admited defeat. Funnilly enough , the bastard that was stealing them from outside my house , hasnt nicked the plastic ones. :devil:
OP
OP
GrahamC230K
GrahamC230K
There were no nicking these!
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
If you check your tyre pressures often , then they would not of have rusted. I have been using metal ones for 2 years or so.
OP
OP
GrahamC230K
GrahamC230K
I ckeck pressures probably once a month. Have had metal caps on this car, the C200 and my 318iS. The out of the blue seazing is what made me post.
fuzzer
Glasgow
F25 X3 20d SE
Might have been a reaction to some road salt that made them fuse.
I must admit , ive never used copper oxide on mine either and they have not stuck.
tosborne
E320 CDI Jan'09
In my handbook, Mercedes-Benz says that Copper grease shouldn't be used on the roadbolts! It doesn't explain why, but maybe they are more likely to come off if they are greased, which wouldn't be cool! Might be worth cheking they are all done up to 110NM!
Shude
Hardcore MB Enthusiast
Cheshire
CLK55 AMG
I used to have these on my old wheels (RIP)
Chrome valves with chrome caps, much nicer than black plastic valves with chrome caps IMHO and only £10 per set:
jimmy
Northamptonshire
Discovery 3 TDV6, Discovery 300TDi - Plaything!
Funnily enough I had new tyres fitted last week and asked if they would fit shiny metal valve stems and caps, the bloke said no he wouldn't recommend it as they can rust on. I thought it was a bit strange but obviously it can happen.
Glenleven
Argyll
E350d cabrio
Has anyone used Spincaps - They are supposed to be thief proof (Probably up to a point) and spin in the NEDS (Non Educated Delinquents) hands. I have ordered a set from the US and hopefully they wil deter ther NEDS - I have only been an MB driver for a few weeks and have lost a set of metal valve caps already. Also thought about dabbing a spot of superglue to them when I leave the car unattended until I get the Spincaps.
Brian WH
East Midlands
JAGUAR XF 3.0D Premium Luxury
Good idea if you never want to blow your tyres up again mate. As getting them off will destroy your valve.:crazy:
Let us know what these Spincaps look like when you have fitted them.:confused:
Glenleven
Argyll
E350d cabrio
What I meant was - To dab superglue to the outside of the caps so that the @rseholes will be stuck to them.
jaymanek
Nuneaton Warwickshire
erm wont the superglue just dry out?
