simbad
- Dec 18, 2005
- CLK 55 AMG
2 things worrying me.
1. i checked the oil and it was a little low about 1/3 on min/max- topped it up.
read manual last night and it said that dipstick checks should be 10mins stopping after normal running temp.
not sure i had done that, so i ran engine warm today and checked. seemed to be about 3 to 4 mm higher than the Max line.
is that a problem, i heard to much oil can cause probs?
2. Big worry. opened the oil filler cap and there was a very small amount of milky/oily slightly white, slightly sludgy oil on the inside of the cap. only a little and a small wipe with a tissue it was gone. although i think i noticed the same about 3/4 weeks ago when i checked the oil, but in between checked once and nothing.
i remember from somewhere this meaning water getting in the engine and causing big probs?
Advice please?
Should i take the car for an oil change to rectify the levels. and any recommendation on type of oil.
Car is yr 2000 CLK 55 AMG
Advice please?
