Was planning to use next week before a 200 mile motorway round trip (Birmingham and back in a day). It says you can double the dose but is there a danger too much could get cleaned off in one go and clog the fuel system up or damage seals? Thanks
I reckon you would gain the most benefit from using this product on a regular basis rather than as a one off solution.
If you intend to use it on regular basis, shouldn't you just use Premium fuels (V-Power etc) instead? Would be simpler than adding the additives yourself and having to worry about the correct ratio / concentration etc. It would also probably cost about the same anyway.
Premium diesel... gives less mpg....
Why is that? I don't generally believe promises of 'helps improve mpg', but why would Premium fuels be LESS efficient? Lower caloric value? Sounds odd...
