Mirror Repeater
EicasTony
Birmingham
Mercedes A Class 2010
Good morning all, I've bought a W169 A Class & sometimes I get a R/H mirror indicator bulb message which results in a higher speed indicator rate as the mirror bulb isn't working. When I turn the ignition off & back on the fault goes & everything is ok. Any ideas? Sounds to me a dodgy wire in the folding mirror? Thank you. Tony.
Most likely wiring is starting to break.
I had this in my E Class, I took the wing mirror off the car to repair the wiring.
Is yours a normal bulb or led?
Had similar with my w204 led, turned out half of them were working but not the other half.
Hi, they’re LED & they seem to work ok
