mb240
This is a very worrying problem over the past few weeks.
The car had low coolant, so I topped up with 1.5litres (hadn't been done in ~ 12 months so I thought nothing of it). A month later, low coolant again.
At the same time, the engine misfires if I give it around 50% throttle, once it gets to aroudn 3000rpm in 4th gear (judging by the number of shifts). Kickdown is fine but it just doesn't seem to be running as smoothly as it should from my memory. Plugs were changed last November. leads and coilpacks were not. On ignition, it used to be totally smooth, but now it seems to sound somewhat cranky; not really noticeable as a problem but definitely different slightly in idle and throttle to my ear.
There is some coolant staining around the engine bay, which I didn't notice before as well.
I am thinking that this is some crazy coolant leak internally and my car is truly buggered
. It's not leaking externally as I had topped up before I left for 10 days and when I got back it was teh same level. However 2 weeks of driving later and it's gone.
Any ideas? It obviously needs some serious investigation, I am just trying to prepare myself for the worst......
