Maybe, maybe not. You need to post the exact tyre dimensions of both tyres including width/diameter & aspect ratio before anyone could tell you.
Russ
215/40/17 front and 245/40/17 rear. Original AMG MB rims
I think the fronts should be 225/45x17, unless someone knows different. I should have mentioned the wheel width is applicable too, i.e. are the wheels 7.5J front & 8.5J rear?
Russ
The wheel size will be stamped on the inside of one of the wheel spokes.
Usual Mercedes fitment is 225/45x17 on a 7.5J front and 245/40x17 on a 8.5J rear. The 215 & 245 you mentioned do not have the same rolling diameter.
(you really need to check the wheel rim width, a 245 needs at least an 8J rim, if fronts are only 7.5J then a 245 is too big)
Russ
I will check the rims.
If the rolling diameter is different, I presume that affects speedo/revs/gearing. Is the pick up for the speed/revs on the rear axles?
Is there any good reason to put 215's on the front (apart from being cheaper)
Totally wrong.
When you have narrower tyres on the front you must increase the aspect ratio so that the diameter front and rear are the same.
Your fronts have a tyre wall depth of 83mm, and the rears 98mm...so the rears are much taller than the front. Nothing will work properly with that set up.
It is less about the actual width of the tyres and all about the diameter.
Does that mean that 245/40/17 rear and 215/40/17 front should not be mixed? That the wall diameter would need to be increased on the 215 front to match the rear?
You should have 225/45 on the front.
the 215's are not suitable. They will affect the vehicles safety systems and invalidate your insurance as they are outside manufacturers specs. The wheels speed "differences" will affect ABS / ABD / ASR / ESP etc.
Thank you for the info. That was what I was feeling. I presume 245/40/17 all round is perfectly safe and sensible.
