Hi folks
recently became proud owner of high up floating truck (aka ml 270 ).
The drivers side door was sticky, when I went to view it. Thought Ill add some grease and wd40 to the latch when I got it home and that would solve the issue. Door did open after a few tries.
However now the door does not open at all, either on the inside or outside, not sure if I activated the child lock. The central locking appears to be working okay. when pulling the outside handle, no clicking noise.
I have tried to take of inside panel, appears to be stuck at the bottom. Does anyone know if the panel would still come of with the door shut, plus any ideas on getting the lock open from the inside. I'm sure the latch must not be opening fully.
only other way I can think of, is breaking the handle and putting something through the hole.
