ML 270 rear window
Discussion in 'Bodywork' started by ML-Simon, Sep 19, 2011.
  1. ML-Simon
    ML-Simon New Member
    17
    Sep 19, 2011
    Car:
    ML 270 cdi
    Hi All
    First post and it's a problem (what am I like).
    I have had my ML 270 cdi for about 4 weeks now and have fixed the peddle with a bolt, had the MAF and inlet manifold replaced. But still have a few thing to get right on it.
    Every time a closed the boot it sounded like there was some thing loos.
    After some looking around I have found the rear screen can be pulled away from seal.
    Is this a common problem?
    If so how much did it cost for you to get it fixed?
    MS-Simon
  2. dokalj
    dokalj Hardcore MB Enthusiast
    1,527
    Feb 23, 2009
  3. OP
    OP
    ML-Simon
    ML-Simon New Member
    17
    Sep 19, 2011
    Car:
    ML 270 cdi
    Thanks for your fast reply dokalj
    If you pull the glass at the edge it will come away from the seal and you can see passed the joint e.g if I look from the edge and push from the in side I can see my fingers! I would think it should be bonded to the rear frame?
    So was I am asking really is "how should the rear glass held on to the boot".
  4. DSM10000
    DSM10000 MB Club Veteran
    6,133
    Jul 12, 2011
    Near Salisbury
    Car:
    E32O CDi Sport, MX5 1.8 Sport, RR 4.2 SC
    Ask a local windscreen replacement company for a quote to re-bond?
  5. dokalj
    1,527
    Feb 23, 2009
    As DSM10000 mentions ask a local windscreen company.
    The whole rear windscreen will have to come out, however be prepared in case they damage it and inform you that a replacement is required.
    Maybe get it fixed before the winter sets in? Would this be covered in your insurance?
    Lastly, which edge are you referring to? Top or bottom and does water enter the vehicle when you wash it?
  6. OP
    OP
    ML-Simon
    ML-Simon New Member
    17
    Sep 19, 2011
    Car:
    ML 270 cdi
    Thanks DSM10000
    That was what I was thinking just needed to check with other owners that is how it should be.
  7. OP
    OP
    ML-Simon
    ML-Simon New Member
    17
    Sep 19, 2011
    Car:
    ML 270 cdi
    So it was the bottom edge on both sides. Facing the back of the car, the left hand side had the bigger problem. Although I don't mind spending cash on the car to keep it how it should be £200+ for a new window seemed a bit much. So off to Halfords for some silicone glue/bond for windows.
    It took some time to get it around the inside of the window and did both left and right outside (between glass and door). This has worked well and the in no movement or sound. It also only cost £10.
    I will post again if there is any change.
Tags:
Share This Page
