Ml oil cooler
Tam67
Uk
Ml 270 cdi
Hi all need some info from somebody more experienced than me.Got an ml 2012 350 blutec had an oil cooler leek so decided to change them turned into a bit of a nightmare.its back on the road and going fine but I have a bracket left over no idea where I removed it from 🤦‍♂️part number A642 150 1373 hoping someone can enlighten me
Many thanks
Can you add a picture please, part number you posted brings an ECU in Google search. So if it is to do with ECU than I would make sure that it goes back where it came from.
I did cooler seals on similar engine and can't remember seeing ECU at all. If it's something else then.... must be over engineered if it runs fine... !)
Here is a picture
Anyone know where this bracket is for
