ML164 Wheel Spacers
T5R+
Want to establish how the ML would look with a little more of a "stanz".
Ideally 5mm but open minded.
I'm in the market for wheel spacers as well..
You will definately NOT notice 5mm, in fact, I'd be surprised if you noticed 15mm..
I'm looking for 25-35 at the moment, but the cost goes up exponentially with the thickness.
If you have the standard 5-spoke 19" wheels, the bolts are long enough to put small spacers on with out lengthening them, but I don't think it's worth it unless you space them out a decent amount.
Bear in mind you will experience slightly different steering feel due the wheel offset (not dramatic) and the wear rate on the wheel bearings will increase, again, not dramatically.
Thanks.
Maybe will go up in size depending on what is offered.
Running 21" AMG rims with 265/40 x 21 and so think that will undoubtedly need new bolts. My current bolts are rusted - so it is the perfect excuse :)
I seem to remember a pair of slim (say 5-10mm) spacers are about 40 quid on ebay, including bolts.
Lots of sellers on there and the technology is not exactly rocket science, so just search by price.
Make sure they are hub-centric or you may get balance problems. Also check what length bolts are supplied with them, some sellers have no idea what a standard bolt length is, so they just guess!
When they're fitted, post a picture, so we can all Oh and Arrr....
hi guys ,
i have a set of 4 25mm hubcentric H&R wheel spacers with all the bolts . bought them for my ml w163 and used them for a month or so before buying some 22" for the car .
i will take £65 plus postage (there pretty heavy) for them , based in Birmingham .
07729077177
Thanks Yuriboy, will keep in mind if decide to go bigger/wider than 5-15mm.
Fear that 25mm may just be too wide for me.
