Hi.
I have a 2005 ML270 and have a problem with the automatic gearbox.
When I apply the brakes in order to stop completely, it does not engage itself into neutral. So although I'm stationary with the brake on, the car is still trying to pull forward.
My temporary solution is to slip it into neutral using the gear shift as I approach a junction and back into drive in order to pull away.
My local independant has cleared down all the histroical error codes and none have reappeared although the problem persisits.
It has had the problem for a few weeks now but doesn't appear to be getting any worse.
Any ideas?
Thanks.
Any ideas?
Thanks.
