I have an ML320 cdi from 2006.
The problems I have are:
- the left mirror does not adjust (only the right one works) - I have tried to look for the fuse, but I don`t know where it is - I only hope this is the problem;
- an error message keeps popping up in the instrument cluster about a bulb;
I have recently changed the left rear indicator bulb, but this works well most of the time, until the error appears. This is after using the left indicator for a bit. It then uses the reversing lamp instead of the indicator bulb.
This is reset after I restart the car.
What should I do about this.
Thanks in advance!
Thanks in advance!
