Tayterash
If I use the key to lift the tailgate it stops about 6" lower than it should. I can push it up easy enough, but is this common, is their a fix?
Don't know if your car is the same, but on my E class estate you can limit how far the tailgate goes up, presumably to stop it hitting your garage roof or similar. Maybe done accidentally on your tailgate? To reset it you press and hold the close button on the tailgate until you hear two short tones.
Pressed. Two pips. Goes all the way up now
