I wondered if there were any mods you can recommend for the exhaust tip which would suit my black ML and if it enriched the sound too? Quite like a deep meaty sound?
2) Twin Oval as in Merc ML brochure (the AMG options) around £240 + vat
3) I have e-mailed a few companies that 'make' what ever you want. I would quite like single oval each side similar to ML55.
1st Enquiry....
This is Jay from MIJ Performance Walsall
Thank you for your enquiry.
The stainless steel dual exit backbox setup you've requested for your Mercedes ML350 will cost only £364.99 this is fully inclusive of fuel discount (£25) , vat & fitting. I can offer you a cat-back dual exit stainless steel exhaust system for only £549.99 all inclusive. I've included 2x oval tailpipes (one either side) in the quotation, you can choose an alternative or upgrade (twin oval tailpipes either side, £22 each) from our extensive range of 40 tailpipes if you wish.
jp exhausts show
31/08/2007 We can make a twin rear section for your car. It costs between £350.00 and £480.00 + VAT depending on what you require. We would need to book your car in and the work will take about 5 hours.
____________________________________
The AMG option easiest but its a lot just for a back box. The other made to measure systems are stainless so lifetime guarantee.
Hi Gucci. I had a stainless steel custom dual quad pipe exhaust system made by Longlife Exhausts systems for my C200K Sport excellent service and quality. Cost less the Kleemann header and cat was £550.00. I know it's not an ML but Longlife took the time in getting the sound i wanted which is a nice deep rumble without the 'boy racer' sound. Hope this helps.
