Hi all,
Hope you can help. Just starting to use my ML55 again after it has stood since December due to lockdown.
I noticed that the engine temp seems to be sitting around 60 even though I’d been out driving for about an hour (to fetch a new battery - the joys of lockdown).
Any thoughts on the cause? I’d normally expect a thermostat issue to cause higher temps (if it failed closed), I suppose failing open could cause it to take longer to heat up, but surely after an hour it should have heated up?
Your thoughts will be appreciated.
Thanks,
Craig
Thanks,
Craig
