miggit
Hi all, I hope that one of you fine chaps might be able to help.... My car wont start
Has played up a few times in the last few months, but taking the key out and trying again did the trick.
Last week it totally died at my parents, and I thought it was just like the time that low pressure pump failed (which turned out to be the O rings) So I had a quick L/P pump change on the drive and still no joy, changed the fuel filter and success!
BUT 36 hours later it totally refused to start.... then I found the High Pressure pump was leaking... So I ordered a rebuild kit and waited.
The seal kit arrived and was fitted, not a hard job if you have good eyes... mine was rebuilt on the office table with the magnifying lamp!! Refitted it and hey presto... wont start. So I was left thinking that the H/P pump rebuild kits aren't as easy as the video made out, so I brought a Bosch Service Centre rebuilt one and fitted that.
And it still wont start... has the odd cough, but never more than 2 injectors firing. My mate came over with a Texa diagnostic tool as the iCarsoft thing I've got refuses to talk with the CDI ECU, the fuel rail is going up to 400 Bar on cranking, so that can't be the fault... I'm beginning to think that I've got a major ECU fault, either the security ECU or the CDI ECU and both will only be accessed by MB Star. And there is the problem...
My local MB specialist wants £60 to read the faults and I've got to take it to them, but the biggest kicker is that they can't do it for a week... by the time I've had it recovered there and back I'll be another £200+ out of pocket and still have a broken car, which if I'm honest is only worth £600.
So I'm trying to get the faults read here, only I can't find anyone!
Cos from where I'm sitting the car is worth way more in bits, but I will miss it!
What does the key transponder chip knock out? Is it everything or will it allow cranking without starting?
I know that I've got fuel pressure, the engine will start on brake cleaner, but it just wont stay running... from what I can see the problem is now with the injectors not firing...Help!
