D
Deleted member 6183
Guest
I know that lots of you will already know about MOBILO but I found it really useful over the Bank holiday weekend.
My S class was showing an error with ABS,ESP,BAS and Pre-Safe. Also the steering was very heavy.
So, I got home and called MOBILO (full dealer service record required), although my car is now out of warranty they still sent a van out.
Now, many times I have read on here that when presented with a problem the poster should get their car on a STAR machine to determine that fault. Well that's exactly what MOBILO man did, showed up that a speed sensor was gone on front N/S.
All credit to the man, he removed the sensor and cleaned it up but the same error showed by the time I reached the end of my drive.
The great bit was it was free and I was able to tell the dealer exactly what was wrong with my car when I took it in for a new one (was also able to check it was in stock beforehand). Or possibly you would want to do the repair yourself - either way a free diagnostic at your own home is pretty nifty.
So next time you have something wrong consider calling MOBILO first, I'm not sure if the car needs to be comletely incapacitated first but the last few times that I have used them the car could be moved however would it be advisable with all the braking safety features shut down?
