grober
MB Master
THE NEW ford Ecoboost 3 cylinder engine has a few of notable features- a timing belt that runs in the engine oil, an exhaust manifold integral with the cylinder head, and an externally balanced crank by use of external balanced flywheel and pulley. Its also a long stroke engine presumably for torque.
Ford currently produces a 1.0-litre turbocharged In-Line three cylinder engine for the EcoBoost family developed at Ford's Dunton Technical Centre in the UK. Production started in April 2012. The 1.0 comes initially in two versions: 74 kW (101 PS; 99 hp) and 88 to 92 kW (120 to 125 PS; 118 to 123 hp). The more powerful version delivers a maximum of 170 N·m (125 lb·ft) from 1,400–4,500 rpm and 200 N·m (148 lb·ft) on overboost, which makes for a broad torque curve when compared to a naturally aspirated gasoline engine . The engine block is cast iron instead of aluminum for up to 50% faster warm-up, at the expense of additional weight. Due to natural vibrations of a 3-cylinder design, the flywheel has been deliberately unbalanced to ensure smooth running, without the use of energy sapping balance shafts. The engine also features an internal timing belt, bathed in the engine oil, for long life and greater efficiency and reduced noise. The exhaust manifold is cast into the cylinder head, reducing warm up times and therefore further aiding efficiency. All this is packaged in an engine block the size of an A4 sheet of paper. With the introduction of face lifted 2013 Ford Fiesta, Ford introduced naturally aspirated version of 1.0 Fox engine. There are two versions producing 65 hp and 80 hp, both engines uses Direct Injection and Ti-VCT like turbocharged versions, start-stop technology is also available.
Ford produces the smallest motor in its history - three cylinder 1.0-Liter EcoBoost
