misterbee
hi, My mono wiper will not return to the home position . It initially nearly jammed up completely but then started wiping okay and goes fully down drivers side when in operation but will not return fully when switched off. I have checked the grease in the hub and it seems well greased and as stated it work fine so i cannot think it would be the motor, bit perplexed by it!, regards, Brian.
Mercedes C200 Classic
