AgentOrange
Hello again...
I'm loving my new C Class so far
I have a few questions though that I thought someone on the forum may be able to answer...
1) I'd like to be able to change the 'addtional speedo' which shows km/h under the clock on the multi-function display to show outside temperature instead. The manual tells me that this isn't possible with UK registered vehicles! Is this correct? I can't imagine why that would be the case?
2) I've connected my phone (iphone 7) via bluetooth so I can stream music (which works well) however I can't see track listings / playlists etc. Should I be able to select artists / playlists etc from the car itself?
3) I got a warning message this morning telling me to check coolant level. I live on a hill and therefore it's difficult to check as the vehicle isn't level, could the fact that I park (pointing downhill) on an incline result in the message being displayed (I'll still check it next time I park somewhere on level ground!). Also, if it does need topping up can anyone confirm the type of coolant I'd need to use (I've just changed the coolant on my motorcycle and have some 'OAT' coolant left so was wondering if I could use that (I've checked online however there seems to be conflicting advice with most people saying 'take it into a Mercedes garage' which seems unneccesary?
4) I've also read conflicting reports on whether I can send routes to the navigation system from my iphone prior to getting into the car, if this is possible it would be very useful for me. I believe my car has COMAND NTG4.7. Does anyone know if it's possible? and if so, what I'd need to do / install on my phone etc.?
Thanks in advance....
Ian
Ian
