This has been driving me nuts for ages!!
After rain the rear offside carpet is often drenched. I initially thought I had traced this to blocked windscreen drains, but after clearing them, the problem persisted.
I since traced the leak to the rubber drain where the drivers side window and rear passenger side window meet - if water is poured into this drain some of its seems to make its way out of the drains in the sill, but most makes its way down the rear passenger footwell.
I have read about drains located at the end of the sills but have no idea how to access them or clean them
Hopefully this sounds familiar to someone here as water ingress seems a pretty common problem!
