Mosselman turbo kit ecu help.
neilrr
Various.
Anybody speak electronics?
I've bought a Mosselman W201 190E 2.0 or 2.3 (8 valve) turbo kit. It's NOS & unused. It's said to raise bhp from 120-ish to 180-ish (& torque similarly) with no internal mods. A low boost bolt on kit which delivers 2.3/2.5-16 power levels from a 2.0 8 valve.
It is complete except I'm missing the electronics, which, as I understand it, kick in at a certain boost & add extra fuel. Now bearing in mind this electronic gizmo is at least 15 years old it must be steam aged technology compared to new stuff.
Mosselman don't have it anymore (though they're slowly looking into making one) so does anyone have a clue where I can get something off the shelf or made that will do the same job?
HERES THE INSTRUCTIONS FROM A 190 16V MOSSELMAN TURBO SETUP.
Lets now hook that computer up. I mounted the computer in the battery compartment behind the firewall. On the computer there is a red wire, a ground wire and two other wires with harnesses on them. Take the red wire and route it to the fuse box and connect the wire to any 12V fuse that is on when the car is on. I used the windshield wiper fuse. Next take the ground wire and connect it to the negative terminal on the battery. Next take one of the harnesses and route it to the fuel distributor head. On the fuel distributor head on the side there is a black box with a factory harness attached to it. Take the factory harness off and connect it to the harness on the computer……then take the computer harness and connect it to the black box. Pretty cool eh? the whole instal detail is here. http://mb190.tripod.com/ under tech/ mosselman turbo install. You could always try these guys.http://www.tdi-plc.com/eurocars.html or if you are feeling cheeky TURBO TECHNICS! ;) plus these guys make what they call an "interceptor" which might do the job.http://www.haltech.com/interceptor.htm they have a couple of UK agents who also might be worth contacting. one is http://www.aet-turbos.co.uk/
